Old 08-17-2012, 08:27 AM
rpatton3's Avatar
rpatton3 rpatton3 is offline
Cobra Make, Engine: Backdraft 874 solid red Roush 427 small block 515 hp
I would check for intake manifold gasket leak because of complexity of angles involved, then valve stem seals and then proper crankshaft ventilation.
I had a 427 FE than needed oil before a gas refill. No leaks while parked, either.
It was a combination of above problems.
Best wishes,
Russell
There were no atheists in the foxholes.
