Warning, potentially boring and long post, read at your own risk
A chronology of what happened at the Monterey Reunion with CSX3170
Tuesday, Arrived at 1:00 PM to be assigned my pit space, we were all parked on “Cobra Row” so it was kind of a neat set up, we could have trailers but trucks had to go out on the Blue parking area.
Wednesday, Went through tech with no issues and then participated in a photograph with all the race cars and the historic cars, we drove around the track in a clock wise direction and got to buzz the tires a couple of times.
Thursday, Some of you will remember I had a very bad vibration problem, it was still there the first time I gassed it up the front straight in the first qualifying session. After 3 laps it really let go and the rear end locked up as I was passing two cars going into turn five sending me backwards off the road. Fortunately the other drivers I just passed missed me, and I was able to limp it off the track and back to the pits with all kinds of clunking and shuddering. It appears that it had some ring gear tooth damage and the track session finished it off. (One person in my vibration post said to check the gear, and he was right) The good news is now I know what it was, the bad news, only 3 laps of practice for the extremely old driver. Some very talented friends then put in a borrowed aluminum 3.54 differential for the next qualifying session and the race.
Friday, Went out in the qualifying session and found that the car broke loose so badly that I could not use anything below 3rd gear with out scaring myself half to death, the car did not feel like it's old self either but I guessed that it was just poor driving on my part and that retirement from driving would be a good idea after the race. We looked the car over after that session and determined that the new differential was slightly over filled and I was getting
oil on my RH rear tire from the vent tube, we then added a vent catch can fashioned from a Coors beer can (we had lots of those). I also should mention that I missed a gear going into the Corkscrew and almost got the wall. I also spun to the inside of 11 and almost hit that wall. After seeing the
oil I decided to put off my retirement for another time but still had no confidence in the car. At this point I was 11th out of 42. We saw a small coolant leak on the bottom of the expansion tank and although my friends told me to fix it I thought it was small enough to ignore, again a real demonstration of ignorance on my part.
Saturday, We got the car gassed and were waiting for the 1:00 PM race when all the guys around me put there suits on, what the heck, a qualifying race that I did not know about that determines the grid for the big race. I jumped in the car and got in line next to Bruce Canepa. I thought they just took lap times and gridded you accordingly (that is how it used to be when I was racing in the really old days) but as all of you know it is where you finish that matters. When the race started I let three or four cars go by assuming that I would get a gap a lay down a quick one Ha. Anyway the car started to feel pretty good other than spinning the tires from corner 11 until I chickened out at the top of the hill. I noticed that it would go anywhere I wanted to and that the new Wilwoods worked exceptionally well. I was a happy camper and started passing cars and going for it. Remember the small leak, well Shelby American had soldered a bung in the bottom of the expansion tank to hold the fan temperature switch, it decided that 47 years was long enough to be there and blew half way out of the tank spraying everything with water including me and the front tires. I then spun on my own water in 2 and decided to come in. We worked like dogs to re-solder the tank before the main race figuring it would be fun to pass some cars. We barely got done when they called the cars to grid, I got in and started the engine but noticed the alternator going nuts, it then died and as you know fuel injectors won't open below about 12.8 volts so we were out of the race! The water from the tank knocked out the alternators VR. Good News: The car had massive power everywhere and worked well on the vintage tires plus I did not smack any walls despite several attempts, I found the vibration and had a blast so it was a good event for me that could have been much worse, think Daytona Coupe.
