Old 08-20-2012, 04:39 PM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
I think that bolt in the back of the Flywheel may hit the block anyways. Have you tried to spin it with the presure plate moved around one hole at a time untill you find the best spot first? You may not need much weight then to balance. Once you've indexed the pressure plate you can drill some holes in the casing to remove metal.
