Old 08-20-2012, 07:02 PM
blykins blykins is offline
I would try the tee and see what it feels like. The reason they don't want you to tee it is because you could possibly get crankcase vapor into the brake booster...but they make a check valve for that.
You can also put a 1/2" spacer with a nipple in it under the carb. Or if you have an intake manifold that will allow, you can use it for a source.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
