Old 08-20-2012, 10:09 PM
rpatton3's Avatar
rpatton3 rpatton3 is offline
Cobra Make, Engine: Backdraft 874 solid red Roush 427 small block 515 hp
Old FE engines had a road draft tune out the back of intake manifold.
293 and 312 y blocks Fords never had PCV unless 1963 and 1964 Pickup trucks had it.
Depending on your engine, you could make your own draft tube.
Does your engine have an oil cap on each valve cover? If so, you could do PCV easily.
There were no atheists in the foxholes.
