Hey forum.
Quick question....I have a new glass inset for the windshield...Is it necessary to remove the two uprights frames (housing the chrome window frame) to change it out or is there enough play )noting the slight top roll over) to loosen of the mounting screws and remove the old screen and frame, replace the glass in the frame with the existing rubber seal and then ease in the new glass and frame assembly..then re-screw to the two brackets into the frame.
Cheers..Adz...
Asking as it looks rather tricky to access the two side frame securing bolts up under the dash
