The easy part is taking it out of the frame, but suggest you have someone else help refitting the new glass because sometimes there can be slight variances with glass manufacturers. I have changed mine 3 times now ( thanks Shannons) and the last one required using a ratchet strap to join the top half of the frame to bottom. Also use silicone spray when fitting glass into rubber.
