Question for those of you with either Flaming River or Ididit steering columns
Trying to search some of the older posts, I can find that the 30" steering column is recommended, what I cannot find is if you needed to have one or two shafts (for a total of 3 u-joints) between the steering column and the rack and pinion.
Is it possible to run a single shaft between the steering column and rack and pinion without interfering with the headers?
I am running a small block ford.
Thanks.
