Old 08-27-2012, 06:41 PM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Older small block and big block chevs ran a press in oil pump pickup. these could come loose with bad results. The standard practice was to tack weld them to the oil pump once in place.
Was the picup hitting the bottom or side of the sump? Something enought to cause some leverage on that weld?
It looks like the whole pickup is just supported off that pipe. It may be worth welding a tab to the pickup and running the tab to one of the oil pump pickup flange bolts for extra support.
Mike Murphy
Melbourne Australia
