So, the cat is out the bag. I moved the cover from the passenger side Head, and on the fotos you can see the results.
I think the Heads are not bad. The engine sound`s and run`s well and it makes not problem to rev them up to 7000 rev`s.
Some coment about the stamped numbers on the Heads?
Valve diameter? Best way to check?
Rico
