Old 03-02-2002, 02:49 PM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Heads will interchange between 351w/302 and 351C with very little machine work, basically just altering water routing---the Cleveland has a dry manifold and the Windsor a wet one. A popular conversion for a few years has been to use a set of 351M/400 heads on a 302/351W. Even the 'small' 351M heads' ports are MUCH bigger than any 302/351W setup, but not as big as the 351C 4v/Boss302 set. The 351C 4v and the Boss 302 heads are almost identical---only water routing is changed by drilling out the Cleveland water port on the head to block surface and installing a freeze plug (make sure it sets BELOW the head mount surface) and drilling a new hole in the head-to-manifold surface so water can flow into the intake. Use a Boss 302 manifold (will have port mismatch without port plates) or use the manifold specifically set up for this swap--I think Roush still sells it pretty reasonably. In reality, this is a lot of work considering how much progress has been made in Windsor heads like the twisted Wedge, etc...You could reverse the process and put a good set of W heads on the C by using the port plates and reversing the water flow proceedure described above....
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
