Old 09-03-2012, 07:21 PM
Tramsey Tramsey is offline
Cobra Make, Engine: CCX 3028
Default Steering Wheel Replacement
I'm looking to replace the Contemporary wood rimmed steering wheel with a leather wrapped one. From the build info furnished when I bought the car it shows a MGB steering column was supplied with the frame. The mounting bolt spacing on the steering wheel measures 62 mm or just under 2.5 inches. This does not compare with any current wheel manufacturers dimensions so it looks like I need a new hub adapter. Splines on the steering shaft measure .75" and looks like 48/50 splines.
Anyone have any info on making a steering wheel swap based on the above info?
Thanks
