Old 09-05-2012, 01:27 PM
patrickt patrickt is online now
Originally Posted by kevins2 View Post
Lots of good information in there that does indicate that the 6 pin system is superior, but $2,800 better? I'm confident that Peter and Doug will steer me in the right direction, which so far is that the 6 pin set-up is a worthy investment.
Kevin, I can usually remember every conversation I had with Peter, Doug, Bob, Jack, etc. verbatim. But, I have absolutely no recollection whatsoever of talking with them about the pin drives... which tells me I probably never did. I think when I sat down with Peter I had already penciled in 6-pin drives and the matter was just never discussed. I can only guess that, at the time, I had dismissed the 5-pins as potentially causing more than $2,500 worth of trouble. On the other hand, there are loads of 5-pin cars running around out there without a lick of trouble. I think if you get the pins straight, and use the high quality, strong material, then 5-pins will be just as good as 6-pins. But, on this one, take a cue from ERA Chas, and don't listen to me... because I honestly don't know.
