Electric fuel pump recommendation
I am building a Classic Roadsters Cobra and plan to run aftermarket EFI on a small block Ford. Most (if not all) electric fuel pumps say that they need mounted lower than the fuel tank and within 2' of the sending unit in order to gravity feed the pump. With the fuel tank hanging lower than the rear frame rails, this seems difficult. Is anyone out there running an electric fuel pump? If so, where have you mounted it and have you had any issues with it? Brand and model recommendations are much appreciated as well.
Thanks.
