Old 09-06-2012, 07:20 PM
Dwight's Avatar
Dwight Dwight is offline
Smile
What fuel pressure will the aftermarket EFI require?
What horsepower will your motor make?
I have a Holley in line 45 PSI pump mounted on my frame rail beside the tank. Maybe six inches above the bottom of the tank. It's a pusher pump, as most are. That is why they need to be as close as possible to the tank pick up and as low as possible.
Mine pick up is in the middle of the tank, front, center, bottom. I have about 18" of hose from the tank to the pump.
I run 40 PSI and my motor makes 400 rear wheel horsepower. I have used the same Holley pump for 12 years and 36,000 miles. Different motors but same pump.
You need a pump that will suppy the amount of gas needed for the horsepower your motor will make at max rpm.
And a fuel line that will support the fuel demand. 3/8" for most street cars.
Jegs has a Holley pump that may work for you.
Holley 12-920 for $172.
Dwight
