Originally Posted by Fletch189
Could it come form the front cover as well? is there a way another way to test for a blow head gasket other than a compression test?
Yes, it could be from the front cover. That's not very common, though.
There are a couple of tests you can do to narrow it down. Use a cooling system test kit to check for pressure changes. Autozone will loan you the kit for free.
Also, you can buy a coolant test kit that checks the coolant for by products of combustion.
Head Gasket or Combustion Leak Test Procedure (Gasoline Engines Only)
http://www.blockchek.com/instructions.htm
