i've used that intake before but only with high riser heads and 12:1 CR
without knowing alot more about the combo, hard to give a direction.
like for instance the cam specs probably calls for a specific gear to use. also may specify a compression ratio.
the intake, head , cam, and carb combo seems workable but with other factors left out hard to say. with just the info you gave seems the CR is too low for the big plenum and that cam.
i have a .630 lift flat tappet ona highriser with the dove dominator intake and opened up port iron heads.....gotta wind her up tight to make power, 7500 plus, your cam may just start making power at 3k.....
my seat of the pants tells me to have 433 or 456 gear behind yours
Fred B
