Old 09-07-2012, 05:34 PM
Barry_R Barry_R is offline
Compression is a bit light for that cam in a "real" 427. It'd be stronger through the midrange with either a shorter duration stick of some more squeeze. I normally run a 254ish deal on the street at 482 cubes for a peak around 6200-6500.
The 750 cfm carbs are perfectly fine. If they are vacuum secondary they will run like a 750 double pumper until the primary airflow is sufficient to open the rears up.
The big plenum intake is pretty huge - I suspect that many of the responders have never laid hands - if even eyes - upon one. Adding two inch spacers makes a big plenum even bigger and will theoretically move the tuning window up into the stratosphere. Might not be the whole deal but certainly a contributor.
Why would you need the spacers? I've run several of these and never needed a spacer unless you're trying to run the carbs in the normal "front to back" orientation or trying the run a 4150 style secondary metering block instead of a 4160 type plate. Both of those are good pure race modifications but really unnecessary for any sort of street build.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
