Hey guys,
I was a little out of it, dealing with life... Finally moved in a place with a garage. So now I am back and starting on my BEAST again. I immediately got in trouble... busted my "ididit" tilt column trying to mount the boss. I am using "moto-lita" steering wheel and boss. the center hole of the boss was too tight.
Want to get advice as to which column to use!
Since I bought the kit from private party along with the parts, I don't have specs, but I would like to keep the steering wheel. It has 6 bolt. the distance between to two top bolts is wider then the rest. My understanding is that the standard is 70mm, equal space for all. So looks like I have to use the boss I have.
Since I have to buy a new column, my question is; do the center bolt of the columns come in different sizes?
So any advice as to which column should work?
Thanks.
