Originally Posted by Caprimaniac
First off i wonder if these AF- values have been obtained in a steady state rpm/load, or if these are what you see while opening the throttle in a pull?
Its a wot pull on a mustang chassis dyno.
If it's a pull- meaning acc pump is doing something, then you know its acc pump tuning needed.
With such a low rpm engine, I would guess you'd need some fuel bypass in the acc pump curcuit.
You could also tweek the springs/ rod to move the length of stroke and when it comes in (if I remember correct).
Yes i am going to put some bypass in the pump shot to even out the afr on the initial hit.
First off you should go with the 37 or maybe smaller main venturis and see what they'll do.
I have a 36 on order.
If it still persist, you might need a emulsion tube giving more fuel at the top and then go down on main fuel.
Couldn't I just keep the same tubes and lower the air jet (same thing as a high speed air bleed on a holey) which would also richen up top, then lower the main jets to get the afr I want.
