Old 09-10-2012, 04:46 PM
kgs365's Avatar
kgs365 kgs365 is offline
Default thanks Patrick
i forgot to add...the kirkham cansiter is two piece and was shipped to me with out locktight in the seal so it was leaking ...i just replaced it with a new canister from kirkham with locktight all sealed up...i adjusted the clamps put the fluid back in went for a ride...came back and again although less there was a drip on the cars frame and fluid sitting around the top of the top clamp....everything is tight i checked it again etc...im wondering if i should try a second clamp?...new hose...
i made sure not to fill the canister to much to rule out coming out the top of the wilwood tops etc..
i used a mirror to look up at the underside of the canister and its dry..the metal tube from the canister down to the top clamp is dry.baffled!
