thanks...i was afraid of that pin hole leak....mine is doing the same thing!...i'm wondering if i have the same kind of hole?...i'll check tonight to see if that it...i wonder if I can just shoulder lead around it?...also anyone know what ERA is using for fluild i have that same blue stuff
thanks
Kevin
Originally Posted by tkb289
Here are a few photos of what I describe in my previous post:
Front can leaking at the seam
Brake fluid quickly migrates
Brake fluid is wicking up from below, not running down the pipe from above
Pin hole leak in solder / braze area
Once the leaks were fixed everything is working well.
I like the the choice that ERA provides with plumbing for the three can setup, and the look and functionality of the Krikham cans
