Old 09-11-2012, 04:18 PM
lvhdude lvhdude is offline
It's been awhile since I did this, but IMHO if you disregaurd the 12O'clock position as zero, and check your runout to find the lowest reading and mark it, zero your indicator there, you will get the maximun runout at 180 degrees from there. This helps by showing exactly how much offset you need in the dowels, (1/2 of the total runout) and exactly which direction to install the dowels. (in line with the high to low reading) In my experience this works the first time around, though it maybe takes a little more time to get the reading. It's easier to rotate the engine a couple of times to double check the readings and high and low points, than to install and remove the scattershield several times. As always recheck to confirm. Note that the flywheel does not have to be on the crank to perform this operation, and your magnetic base may fit easier on the bare crank.
Just my $0.02, Good luck!
