  #25 (permalink)
Old 09-12-2012, 12:22 PM
Barry_R Barry_R is offline
If you had measurable side clearance of .024 you had plenty of oil slinging - one area where Jerry and I will have to agree to disagree. The squirt holes have been dropped from everything OEM for well over a decade.
I do see some side loading on the bearing that could be a crank issue with wear on one side of the rods. Unlikely that every rod would be bent or every pin would be off angle - crank is tha only item left.
The V series bearings are just fine - lead indium is good for non-seizure and might have helped you. All bearings have a degree of eccentricity - your's shows circular "pops" in the face that might indicate cavitation - a failure of the oil film due to excess clearance.
Looks like a fair amount of fine debris got against those skirts - build debris or?
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
