Thread: Gas Pedal
Old 09-12-2012, 01:52 PM
Hank Steckel's Avatar
Hank Steckel Hank Steckel is offline
Cobra Make, Engine: BDR #258, British Racing Green/Silver Stripes, Gray Int., 351W, T5
Originally Posted by jeffg View Post
Hi, new to BDR ownership. My car (#88)'s gas pedal has a very long travel & the return is very weak, even with 2 springs on the carb. Was there a change to the gas pedal/throttle cable design in later cars?
Any help is appreciated.
My guess is you ought to move the ball joint on the carb throttle arm to a spot closer in to the shaft. That would shorten your gas pedal travel. You may need a stronger spring(s) as well. Try moving where the cable connects to the carb throttle arm 1st.
Hank Steckel
BDR #258
San Diego
I never make mistakes. I thought I did once, but I was wrong.
