Old 09-13-2012, 03:04 PM
Jim Kellogg's Avatar
Jim Kellogg Jim Kellogg is offline
Cobra Make, Engine: Superformance MKIII #887, drive it a lot!
Send a message via Yahoo to Jim Kellogg
I would try removing the speedo and/or the tach to gain better access to the wiring. They are held in with knurled nuts (2 per), and of course the speedo cable and wiring. The illumination lights just snap in the back of the gauges. Take the speedo cable off the reverser attached to the speedo.
If you can get your hands through those holes you should be able to get to the switches without removing the whole dash assembly.
Disconnect the battery first!
Jim Kellogg
