I have not had that much oil with T&Ds. Are you only oiling through pushrods - you've blocked the oil feed in the deck? As long as that is true, you can purchse restricted pushrods that will cut down on the flow - I have only used them a couple times.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
