Old 03-03-2002, 06:52 PM
Cobra 29 Cobra 29 is offline
Cobra Make, Engine: ERA 427SC FMS 351W
Default Lines between Master Cylinders & Remote Reservoirs
My Cobra is has a combination of metal lines and hose between the remote reserviors and the master cylinders. The metal lines lead away from the reservoirs and then connect to rubber hose which connects to the masters cylinders. To reduce the chance of leaks (eliminating connections) would it be better to run the rubber line between the reserviors and master cylinders? What type of hose should I purchase to ensure compatability with the brake fluid?
