  #36 (permalink)
Old 09-20-2012, 05:10 PM
streetbeast's Avatar
streetbeast streetbeast is offline
Cobra Make, Engine: Street Beast, 427FE Replica (390 Block)
Thanks RedEye, I am using an FE motor with 4sp. I may have some room if I cut the tunnel, but would rather not. It won't give me enough anyway. Tilton floor mount assembly would give me enough room but I still have to figure out if I would have enough leg room. I am only 6' but with long limbs, more the size of 6' 2-3", so the leg room is also very important. I would give it serious thought when I get to it.
Someone advised me to only tackle one thing at a time. Its a good advice. For now figuring out steering is my priority. I think I have that figured, just have to confirm the the length of the column and the splines for the boss.
As for your rear end, is it 4link with panhard bar? if so you should have at least three mounting points for the coil-overs. In my opinion cutting the body shell should be the last resort.
Having said that, now that I think about it, when I got mine, there was already some cutting and patching done in front towards the top of rear wheel well.
Will let you know if that had anything to do with it. Won't be able to check for a while though.
