Not much progress lately - too hot this summer! Now I have some other projects I have to get done. But I did get my 2-1/2 inch tail pipes for my undercar - rear exit finished up. This thing will breath through the exhaust anyway. I decided to paint them with high temperature paint since they would be pretty awkward to ship off for plating. The headers, head pipes, mufflers and clamps are going off for ceramic plating. I plan to also wrap the portion of the tailpipes behind the tire since I will only have about 1/2 inch clearance on either side. I will have a hangar at the rear of the muffler and at the tip of the tailpipes (hanger is shown). I also have a bracket at the high point behind the tire that will bolt through the aluminum panel to the structural frame rail in a tapped hole. Rubber hangar material washers will isolate the hangar. This will rigidly hold the pipe laterally in position behind the wheel so it can't move around.
Also waiting on a fabricated rear intake manifold breather from Survivor Motorsports to solve the interference problem with the heater hoses.
I need to start on the wiring next and once that is in I should be close to firing it off at last.
Dan
