Old 03-04-2002, 08:41 AM
CSX 4027's Avatar
CSX 4027 CSX 4027 is offline
Cobra Make, Engine: Sold 3047 & 3002 in 2012
Default No Rubber
If you ask any of the hose companies, I do not think you will get any to put their blessing on use with brake fluid. It will expand and distort the inside of the line causing a non consistent pedal and of course will leak. Use metal or steel braided teflon made for brake fluids.
If you want the original rubber look like I did, get your line sized in steel braided teflon and then slip them into a rubber line to cover the steel braid. It will give you the look you want along with an extra layer of protection
Evan, did you get that
Steve Sunshine
www.competitionlife.com
"Hurry Up And Live"
