Old 03-04-2002, 09:36 AM
Whaler Whaler is offline
I have not connected my feed lines to my floor mounted wildwood masters yet. My builder mounted the three remotes on the firewall between the footboxes. The original rubber hoses are there all right but they are not long enough to get to where they should.
I also do not have my pieces on the masters where the line would have connected as he does not like them and said he was having metal pieces machines.
In the end we will end up using hardline and tube fittings to connect the feed lines... If I knew right now what the threads were on the ports of these machined pieces, I would be working on it as we speak.
Likely be hard line from the masters up to the points on the firewall...could likely skip the rubber too..
Tim
