Another consideration on fit
I was just lookiing at my car. I have the 850 with the holley supplied dual feel fuel line...it drops down at the stock angle about 4 inches. The extreme ends look to be lower than the carb flange on the manifold..I have the edelbrock RPM.
So I am wondering does the bottom of the turkey pan need some serious work or is the pan bottom contoured at all...IE flat bottom or will I be opening up here and there...I thought about the throttle linkage on the other side as well. Maybe in the worst case I can't use the nice feed line holley supplied with the carb and have to make something that does not drop down so far into the intake runners and stay above the carb flange line.
Tim
