Old 09-23-2012, 07:37 PM
cobrafx cobrafx is offline
Cobra Make, Engine: Aussie 351C, TKO, UNK maker
Originally Posted by tcrist View Post
What I did with mine is loosely bolt the engine in where I thought it should be, mount the headers and side pipes. For mine the side pipe has a particular location to mount to near the rear wheels. Now I am unsure how yours is and if you are using side pipes or not, this is just how I did mine.
As for the oil filter, you can use a short, half quart filter or use a remote one. I chose a remote filter setup.
Hope this helps.
I dont have pipes, I get to make them. If there was some ready made for a 351C that would be cool. Does yours have the oil filter located similarly? Does yours have the Mustang 2 front end also? I will try to put a pic on here showing how high the engine sits.
edit: Rats, thought I had a pic but I didnt. The rear of the engine is VERY easily 8 inches ahead of the firewall and the valve covers can not be an inch below the level of the hood opening.
