you will need the emerg cables hooked up.
if the master was empty, you should bench bleed it first, then gravity or pressure bleed the system. takes a lot of pumping to fill up the lines and calipers.....and not letting the master run all the fluid out is very good advice.
when i did mine i got it to the point of it being drivable, then took it to a shop to pressure bleed the whole system through the master with compressed air.
Fred B
