If you do one at a time, bleed the farthest caliper first. With a one way valve in the bleeding tube. Make sure you lift you foot of the pedal after each stroke. To intially bleed the mc, put your finger over the outlet, so when you release the pedal, the vacuum will suck the fluid into the mc.
JD
