you can pull back that rubber over the brake rod and measure the master cylinder bore--since its leaking and needs replacing, buy one that is 1/8 smaller bore which will increase your line pressure----
I see that you have speed bleeder screws in your wheel cylinders, thats a gonna make bleeding your brakes a one man job!!!!!!!!
