Old 09-28-2012, 03:55 PM
grybrd123 grybrd123 is offline
Cobra Make, Engine: N/A
Default How much coolant in a 351W
After repeated flushes, the block is now filled with distilled water. I know the volume of the rest of the system. If I know how much the block holds, I can calculate the total amount of antifreeze required to make 50%. Filling the radiator and hoses with 50% will result in a less concentrated solution because the water in the block will dilute it.
