Old 10-02-2012, 10:43 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
Originally Posted by Clois Harlan View Post
you are probably right Mark. Have you ever used the automatic sway bar adjuster while driving on a track? If so, could you tell there was a significant difference in the handling?
Clois
i don't have extensive experience with it on track but i do use it on the street and can tell a significant difference between full soft and where it is adjusted for the street which would be similar to the track.
at an autocross because the car was not designed for the tight corners i made some adjustments using the sway bars to be able to slide the rear around the turns and it worked well, very predictable.
