Old 10-03-2012, 11:20 AM
Jim Kellogg's Avatar
Jim Kellogg Jim Kellogg is offline
Cobra Make, Engine: Superformance MKIII #887, drive it a lot!
Send a message via Yahoo to Jim Kellogg
I have run the Beaumont system on my SPF for several years now, and recommend the system to any Cobra owner that runs his Cobra hard, or runs in cold weather. I do both, so it is a perfect fit for me!
I have run my SPF year-round in upstate NY, in temps as low as -10f. In the past, I used cardboard to block my oil cooler, and partially blocked the radiator in those temps to get the oil up to temp. Now I close the valve (shut off the oil cooler) in super low temps, and change the setting as needed for the rest of the year. Super easy to do as I mounted it on the crossmember directly in front of the engine.
I also changed to a larger cooler (from Olthoff racing) and changed the whole system out to AN12 lines.
A highly recommended upgrade.
Jim Kellogg
