Thread: Progress DRB#66
Old 10-07-2012, 05:55 PM
sevenohms sevenohms is offline
Cobra Make, Engine: Venom, BF XR8 260kw, 6 speed auto
Hiya, I am also blessed with the Boss Engine, I'd agree that its worth doing the timing chain tensioner whilst its out, but as mine is a BF it is better, or so they say, mine was cast alloy with plastic.
The oil pump gears is a a tricky one. I took the advice of my respected engine builder who has built a number of these engines on Boost, and he said it was ok, as long as you didn't over rev them. If you have it apart, it can be worth buying a billet one (as the stock is cast) for safety. I think Herrod is a good source for the pumps. I just won't bump the rev limter up...
When i rebuilt mine, I put all new rings, bearings etc, plus a set of high tension head bolts ($600 a set). Easy to get parts for, if you replace the sump gasket, prepare to cough, $700+. No idea why.
Nathan
Originally Posted by Route 66 View Post
Hi all, as per our previous post getting the engine for our project has spurred plenty of questions. As is typical or so I have read about the BA Mk1 our engine has the start up timing chain rattle. The replacement with later model metal tensioner seems straight forward enough. I have read and been told that replacing the oil pump gears at the same time is a smart option. The Service Mgr at local ford dealer agrees with the tensioner a but reckons the pumps don't give them any issues?
Our main query is the best source for the parts, either tensioners and/or pump gears? In the old days sourcing Chevy parts or even Cleveland or Windsor parts were everywhere but I find very few references to later model XR8/Boss/5.4L parts. If anyone has some suggestions we'd really appreciate the advice.
Regards
Route 66 Qld
