Old 03-05-2002, 09:10 AM
Richard Hudgins's Avatar
Richard Hudgins Richard Hudgins is offline
Cobra Make, Engine: Porsche 928 S4
Silk,
Don't your master cylinders bolt to the pedal assembly?
Also, the rod that goes from the pedal to the MC pivots at the MC piston. Therefore, a little misalignment should not cause this problem.
It seems to me that Wilwood must have a material problem in the seals. Glycerin (the base for normal brake fluid) should not effect buna-n or viton, which are the nromal materials for brake seals.
I am going to take some Wilwood MC's apart and soak the seals in hot brake fluid (195 f) and see if there is any rapid degredation of the material.
Best regards,
Richard Hudgins
