Old 10-09-2012, 07:46 PM
tcrist tcrist is offline
You will have to get new or modify the threaded rods that hole the bumperettes on.
Get new nuts and washers for the assembly.
You will probably have to cut the spacer tubes to the length that you want unless you want them to stick out as far as your bumperettes are.
Remember when cutting, measure 3 or 4 times, then before you cut, measure again.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
