Originally Posted by mickmate
Check the vertical spacing on your mounts. It should be 2.25" and is an easy swap. Even if it's not you have some options on either different spacing or blank QJ's. I make them OE style or custom and there are other suppliers out there. As Terry suggests you could use a piece of old plumbing or conduit, with washers if need be. That will set up correct spacer lengths before you cut any nice ones.
Nick, Don't forget to tell him about duct taping thick foam around his shins when working in the garage.
