Old 10-10-2012, 05:27 PM
cobrafx cobrafx is offline
Cobra Make, Engine: Aussie 351C, TKO, UNK maker
It's not always the bellhousing's fault Jaime. There's a lot of things that can change crankshaft centerline....line boring/honing the block, manufacturing tolerances between the block, bellhousing, etc.
It's pretty common to have to do this, especially on older McLeod and Lakewood bellhousings.
Had a feeling there was going to be an issue when I noticed the holes on the flange were drilled/punched into the radius of the 'bell'. No worries, just something new to me. I am interested to see what (if any) difference installing the flywheel makes mounting the indicator base to it. Thanks again for the replies.
Jaime
