I use a Gunson's EZ Bleed with 5lbs. of air in my portable tank. Attach the inline reservoir to the portable tank and the Brake/Clutch reservoir and just open the bleed screw on the slave cylinder. Whole operation takes about 5 minutes to bleed the master and slave and I don't need anyone else to help me. The inline reservoir holds about 8 oz. of fluid so you never really have to worry about running out of fluid while you're bleeding the system.
DonC
