Old 10-14-2012, 03:12 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Jaydee View Post
Is the piston in the master cylinder bottoming out on the circlip. If not, then the port to the reservoir will be blocked by the cup. Occasionally, if the cup has swelled for any reason, it will also block the port.
JD
A very good point.
If the slave won't gravity bleed, this could be the reason.
Gary
