springs
Hi Bruce
We allways suggest 350 lbs on the front and 300 lbs on the rear . I have just had an engineer do a road test for rego . His 15 kms test run is like a goat track at the back of Lismore NSW . He was quite pleased as with others with the ride and handling . Unsure where you are driving the Cobra . I would suggest you talk to either King spings
or a spring manufature about the progress spings . One of the Cobra racers is trying Penski shocks to see if he can inprove his times with the two adjustment style . Do not forget the AVO is rebuildable and REg can alter the valving . The others , well look into if they can be rebuilt . We had some problems with leaking shafts but those have been fixed under warranty .
Warwick.
