As I understand it, the length of the input shaft is dictated by the depth of the bell housing. The short input shaft is for when the Tremec is replacing a toploader 4 speed trans. and you are using a stock depth bellhousing. The long input shaft is for when you are using a later model bell housing that was used in conjunction with a T-5 type trans, or an aftermarket bell housing that is deeper than stock. Right now, I am using a stock depth toploader bell housing with the short shaft. When I install my FE engine I will be changing out the input shaft with the long shaft, because I'm using the Quicktime bell housing that calls for the longer shaft. So, in closing, determine which bell housing you have and go from there.
If I have totally confused you, I'm sure Brent from B2 Motorsports will chime in soon. He's the resident expert and he'll be able to help you.
