Damage:
The original QJs are attached to the radiator frame which is somewhat flexible.
Lifting the car will cause the holes in the body where the QJ are mounted to elongate.
Same in the rear, although the frame is a bit more sturdy there.
Old pics show that. I saw one in one of my books.
The spacing would be dictated by the 289 spacing, if you re-use your 289 lift after you bought your 427SC :-)
If I don't respond anymore, that's because I can't log in
